vrharley
- Nov 1, 2010
Neebie here picked up a complete proactive suspension with 2K on for less then $100 what is all need to install into a RX-1? I can still get the brackets out of the 06 Nytro that I got it from. Any suggestions would be great. running it with a ripsaw 1.25 track no studs in a 03 RX-1 121inch
Almost700
- Oct 7, 2010
- Zeeland Michigan
- www.jasonbakker.com
If you can still access the donor sled, make a template off that tunnel to get measurements. I would get the brackets if you can.
Use cardboard for template.
