thedutchman
I have 2005 RX1 W/CPR Lake Turbo installed by vender. I've had new low compression pistons, heavy connecting rods, Heavy Hitter clutch kit added. I've put 200 miles on since the addition. Prior to installtion of the turbo the stock machine could easily reach 120+ MPH. Currently the best I can do is 105 MPH max and am using about 1 quart of oil in 100 miles. I'm no mechanic, so I don't normally play with engines and adjustments, but something is obviously wrong where do I start?? Any suggestions would be appreciated.
- Sauk Prairie, WI
- www.ty4stroke.com
Call Jeff Simon at 414-698-6611. You definetely have a problem with the install...BBY
Bossman
I second what BBY said, if you are running a lake race turbo and that is your results I would get ahold of Jeff. Being you are both in WI I personally would see if he would fix it for ya. It might cost ya some coin but you already have plenty into it and have gone backwards. And by the way GO BEARS!
Skydog
GO BEARS!!!! YES!!
I would not ride it.
Skydog
Skydog
marv, drop it off here, i will try to get to it this weekend. thanks jeff
- 13K
