shockwave
- Feb 25, 2010
- St Paul d'abbotsford Québec
- 09 Phazer RTX
I change my handle bar to a wide 32 inch Fly carbon bar. I also wanted to solve one problem that I had last year which was my hand warmers not getting hot enough on cold days, that is one of the reason that I got the carbon bar. I install new Kimpex hand warmers with ATV grip over top. My problem now, is that I have less heat then last year. What do you guys think? Are the Kimpex hand warmers are not the best choice, or ATV grips are too thick?
mtkaboater
Different brands of grip warmers draw amperage differently. You will need to determine the resistance across your new warmers vs the old ones. Rockmeister here on TY is the guru. You should check him and his threads out - there is a LOT of discussion on this topic
shockwave
- Feb 25, 2010
- 09 Phazer RTX
mtkaboater said:Different brands of grip warmers draw amperage differently. You will need to determine the resistance across your new warmers vs the old ones. Rockmeister here on TY is the guru. You should check him and his threads out - there is a LOT of discussion on this topic
Thanks, I sent him a PM
shockwave
- Feb 25, 2010
- 09 Phazer RTX
I should also add that the Kimpex hand warmer are connected to the Yamaha factory control.
