Project: Phazer MTX "facelift"
Some pics from making vent kits
Cheap material to the vent kits from bicycle baskets :)
I used my old parts to make holes and make the vent kit fits
I made some moulds in wood to be able to press the grill
This way the grill will be at same level as the fairings
The grill will also be covers with fabric
All pieces ready for the clutch side
I really like the grills, shows that extra attention to detail. I also vote for the upper version of the slide rail mod. ;)!
A nice box arrived with some new coluors to the sled :)
Used but not damaged
Complete kit from an Venture Lite
After some washing they are ready to be modified
Here I don+t know what Yamaha was thinking...half of the radiator is covered
Better :)
I did also make holes on the rearside to let the air out
Hole to let ait into the clutchside
Is that big hole on the front side of the clutch side panel? What kind of material are you going to use to keep the water out?
Yes the hole is on the fronside of the clutch panel
I will use a grill cover with meshfabric...a fabric that let air go trough but keeps water/snow on the outside.
Should be the same material as the frogskinz are made of.
What do you guys think, should go for some new designs on the panels? Or should I keep it clean when I uses carbonfiber...and leave the original design.
It´s mostly the blue panel under the seat that I have in mind to change...
Thanks!
It´s nice if my tread can help others also. I have got alot of help and ideas from this forum.
I have been away alot lately with my job but will be back home again tomorrow, so later on next week there will be udates with more pics :)
