Proper Engine Oil for 2007 Phazer FX
jkraeger
Utica, NY
I've got the service manual and it state 0w 30. But then there is a caution about not using oil with an API Service Grade of CD or higher. Mobile and Amsoil are both rated CF. I assume CF is higher. Does this mean I'm stuck with using Yamalube? The caution is in regards to starter clutch slippage.
Thanks,
Jeff
I just changed mine this weekend used the new Yamalube 0w40 full synthetic. It is a Pain to change the filter. I installed a k&n filter which has a nut on the top to use a 17mm wrench to tighten/loosen makes it a lot easier since there is no frickin way you can get a regular filter wrench in there.
I run the Amsoil now but when I was in warrantee I stuck to the Yamalube.That way no questions.Never need any warrantee for motor though.
Same here Amsoil 0w40 I run this in all my stuff.Sled,Quads and bikes.Winter and summer.Never had any issue.
Glad to here that Amsoil 0-40 is good. I just bought 7 quarts of it (and 1 bottle of 2-smoke oil) at an auction for $35 (includes tax and buyers premium). I have to drive over and get it, but I figure I'll have about fifty bucks invested.
