JERSEYJOE
OK what is the proper way to set the toe on an Apex?
Is this correct: have a rider sit on the sled, push down the front end and let it set. can I use the front and rear runner studs as measuring points? should I shoot for 0 toe or 1/8 inch toe out?
BTW sled is lowered to where the front A Arms are parallel to the ground
limiter strap is one position up from middle
rear suspension drops 3 inches when I sit on it.
