WinderFab
- Mar 1, 2009
- Woodbridge, ON
- 2020 Sidewinder Ltx GT
hey guys
over the weekend i was installing a set of skis and aligning the skis with the proper toe out
i set the skis to 0 toe to start off, straight with the track, track is perfect inline between the rails all the way front to back
i noticed that the measurement between the ski and the track are not the same on both sides
example... I'll get 115/8'' from track to left ski (front/rear carbide nut) which would be of course 0 toe, now the right side I'll get 12''
shouldn't the skis be the same on both sides, everything is fine, nothing bent, suspension a arms and everything else is tight
is this normal, i can't remember if my other sleds had this or not
any help would be great
bwilly
Will be checkin mine this weekend, let you know next week. Shouldn't really matter
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
Are you positive nothing's bent?
WinderFab
- Mar 1, 2009
- Woodbridge, ON
Hey Grimm,
i know it sounds crazy,
i had the sled since new and I'm 100% positive nothing is bent or worn,
this coming weekend I'll post the actual measurements,
i had a viper prior to the apex and i think it was off too...
Malmlof
Fabio, have you measured how the track sits in relation to the tunnel?
Also if the track is symmetrical, regarding width from clips/nobs and out?
dhkr123
You're measuring between something that is flexible (track) and something that is flexible (ski). You are NEVER going to get a perfect measurement. Your difference is only 3/8" -- WELL within any sane margin of error for what you are measuring.
WinderFab
- Mar 1, 2009
- Woodbridge, ON
Thanks guys for the response,
Malmlof I'll check that to see if the track is off or not from side to side,
Thanks again
Thanks again
- 6K
