sbot69
What Yamaha tools do I need to pull primary clutch on 2014 LTX SE? Do I need the puller and holder? Also do you have to have the spider separator to take it apart? Thanks in advance! SNOW, SNOW, SNOW❄
Just a puller to remove, but to "take it apart" you'll need tools IF you need to do this. The spider and main are one piece and the back sheave spins off freeing up the moveable sheave. There is a long #*$&@ spanner type wrench and a sheave holding fixture that they use for this. Also heat for the red Loctite.
4StrokeAddict
- Apr 13, 2015
- Michigan
- 2015 SR Viper LTX SE
Pulling them is easy. As others have said, all you need is a yamaha pulling tool. I've seen them for $30-50. If you were closer, I would lend you mine. Just use a crow bar through the clutch to hold it in place and use a wrench to pop it loose. Go slow, when it pops, it can really pop. Some folks find theirs wont pop after lots of force. If yours is one that isn't popping, you can inject some grease in the hole to give yourself some hydraulic pressure when you screw the tool back in. There are several how to threads on here. Yamaha clutches haven't changed in 18+ years, so any of those tools or videos should be useful...
mtotguy
- Jan 20, 2011
- Montague, Michigan
- 2016 Rush 800, 2014 Viper RTX, 1983 Excel 3
Use an impact wrench rather than trying the crow bar and end wrench method. If you don't have one borrow one. It's so much easier. You can buy an electric impact wrench cheap for occasional use.
Allan
- Oct 19, 2014
- Newfoundland
- 2016 Sr Viper XTX
Have anyone ever used water with Thread seal tape and original bolt.
Never tried this but have seen where people have did it this way.
4StrokeAddict
- Apr 13, 2015
- Michigan
Didn't need to with just an impact wrench and crowbar, but I've heard of some that were on so good that they needed hydraulic pressure to get to pop.
Studroes144
- Oct 30, 2013
Don't buy a cheap puller, under a lot of force they can bend and potentially ruin the threads inside the crank that the clutch bolt threads into. I have an EPI puller, cost like $40 and used it a lot with an impact and it's still in perfect shape. Just stay away from the cheap $20 ones
If you are going to need parts you could just order them plus puller in advance. When I did mine I had plans to run Ulmer clutch kit and also have him machine my clutches so I got the puller from him right away.
super1c
Moderator
- Apr 10, 2010
- Freeland - Otsego lake, MI
- 22 sidewinder LTX-LE
I do the water trick on all my clutches. Dont like the idea of the impact on the clutch, i used to but got away from it. With water and tape pops off like butter every year. Also just a dab (and i mean a dab) of anti seize on the crank shaft to prevent rust.
Allan
- Oct 19, 2014
- Newfoundland
- 2016 Sr Viper XTX
Do you use the clutch bolt ?I do the water trick on all my clutches. Dont like the idea of the impact on the clutch, i used to but got away from it. With water and tape pops off like butter every year. Also just a dab (and i mean a dab) of anti seize on the crank shaft to prevent rust.
super1c
Moderator
- Apr 10, 2010
No I've always used a cluch puller. I went to the water trick after I turned a OEM puller into a curly fry.Do you use the clutch bolt ?
nherbst454
- Feb 25, 2014
- Woodbury, MN
- 2014 SR Viper XTX-SE
I have a clutch puller and it works well. I used the water / Teflon tape trick and it worked as well but kind of a pain tipping the sled to get the water in. A good puller is better to be able to rebuild and clean the clutch annually. I also make sure to use some anti-seize to keep the threads from galling.
sbot69
What exactly does the clutch holder do? It says in service manual to put it on clutch when pulling it. It looks like a band that wraps around outer sheeve with a handle.
- Nov 29, 2009
- sabattus, maine
It holds back on the clutch so it doesn't just spin while you try to tighten the puller. I just stick a piece of half inch NP pipe through the clutch towers to hold back. There's many ways to do it. Using an impact it doesn't take much to keep it from spinning. I don't like the idea of an impact banging the crank bearings but plenty of people do it. Just like I'm sure others don't like the idea of sticking something through the clutch towers. Plenty of us do that as well.What exactly does the clutch holder do? It says in service manual to put it on clutch when pulling it. It looks like a band that wraps around outer sheeve with a handle.
Alsim
- Oct 6, 2014
- LTX SE 2018
