Pump Fuel Apex to 18#'s ?
It depends on how much boost you are using and how much you keep the butterflies wide open. I run 13-14 psi and with the shim I have the meth starting at 8 psi and coming on full at 20-22 psi. I do not need full meth at the boost I am running. If I were just doing 1000 ft w/o runs that tank with the kit would last 1 tank to 1 1/2 tanks. I also have the failsafe kit, I was nervous about running out until I got a feel for the usage. I still am happy I got the failsafe, alot of money riding on my meth.
fullthrottle800 said:
I have the meth injection but afraid to use it, its hurricanes set up. Does the little jug that comes in his kit last an entire tank of fuel when set up correctly?
I run two of them for a full gallon of meth :-)
Failsafe is a must
