Rick Chalut
- Oct 5, 2014
- 2009 nytro xtx
Hello
I have just purchased an 08 nytro rtx . It has a pcv, exhaust, and k&n intake. Took it down the rode and it fouled a plug. Changed the plug and it ran great again but after 2 minutes it fouled another one. I use to have a dragon that would foul plugs if I touched the throttle be for it was hot. So I did let it warm up. Any ideas?
Thanks guys
Thanks guys
newfie09xtx
- Jul 13, 2011
- Corner Brook, NL
- 2016 Polaris Switchback 800 Pro S
With the nytro you shouldn't touch the throttle till the red light goes off on the dash. What plugs are you running? I didn't have much luck with cr10ek and fouled them easy. Put my original plugs back in and didn't have an issue since.
Rick Chalut
- Oct 5, 2014
- 2009 nytro xtx
I am running the stock plugs. The the ngk cr9e. Should I get a set of the eya? They were better in the 2 strokes for plug fouling.
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
Put it on a track stand and run it good, get here good and hot if it fouls a plug you will need to look at the pcv. Thinking it was not up to temp.
Rick Chalut
- Oct 5, 2014
- 2009 nytro xtx
I am pretty sure it was up to temp. I will try another set of plugs tomorrow. I have the trail tank on it so it is a pain to change them. I am leaning towards the pcv also. Not sure what I can do with that though.
Rick Chalut
- Oct 5, 2014
- 2009 nytro xtx
Does anyone have a new map for the pcv?
Nytros rule
- Jan 30, 2011
- Rider Nation
- 2014 Black Viper XTX
Who's map did you get.
I got mine from Ulmer and it has been flawless.
Rick Chalut
- Oct 5, 2014
- 2009 nytro xtx
I just got the sled. The receipt for the pcv was from Ulmer.
Nytros rule
- Jan 30, 2011
- Rider Nation
I told Allen what I had done and he sent out the PCV programmed and it's worked, as I said flawlessly.
If you suspect the program or programer just unplug it and return to stock, (just don't run it to hard you may be a little to lean)
If it is the PCV contact Ulmer racing he seems to better than most about standing behind his products.
