juxtoposed
juxtoposed
Sno-Xr
I think I would be concerned with the track grabbing the back of the tunnel when you bottom out! Have you squashed the skid down completely to see if there is clearence?
4Fighter
Heck ya! The aftermarket extensions look SWEET!
DaveyBoy
The first thing i would do is get rid of the long flap go get a shorter 1 i have had no problems with mine since i did that plus the shorter looks better IMO
WarriorBeads
- Dec 4, 2005
- Peterborough, Ontario, Canada
- 2004 Rx Warrior
Don't think it would get caught up in the track unless you've got reverse and back over it - I ruined my stock flap on my Warrior that way on the FIRST ride! Looked like this guy had taken' a few shots at it. Anyway, I've got a shorty on order and expect that will take care of it......The tunnel extensions do look cool though, but then again I guess I'm kinda partial to mine
juxtoposed
I had it fully compressed with the asphalt track on it and I had alot of clearance, but that don't mean that the extra 1.25 of the ripsaw won't catch. I'll have to get several of my fatest friends on the back and see how she does. Thanks for the heads up.
LazyBastard
What you might want to do to test... (everytime I perform back end surgery with unknown parts I do this).. is remove all the SPRINGS from the skid, lift it on a rope, and push UP on the REAR AXLE while allowing the front to sag. It is necessary to do this because you need to make sure that there is clearance while a) at maximum compression, and b) at maximum TRANSFER.
Snomad
The flap will likely suck into the tunnel at high speed. I stretched mine to 136 with extensions and have had it happen at high speed. The
1 1/4" track creates quite a wind going into the tunnel. This was without the stock flap reinforcement that won't fit after you put tunnel extensions on. I wound up creating a flap stiffener out of spring steel that solved my problem. It looks like you still have the stock flap stiffener so perhaps you will be OK. Do a lake run and have someone observe your flap. That 128 doesn't look too long for the tunnel.
