Put on a roller secondary!
Mine is a Hauck Magnum Roller and it is sweet and uses the stock Yamaha helixes.
I live in the US and sent it them to machine and install for $60.00. For you Canadian's not much of an option sorry.
So if the machining has to be done professionally, my option would be Mountain Perf, unless there are others that don't require machining.
well funny you should ask upbushman, was just thinking of digging into clutches again. we just finally got snow, and i dont remember what helix i ended up sticking with last year. lol I'll update you when i figure it out. What i can say is that no matter what i did i was never able to get completely get rid of bog when climbing in steep deep(under heavy load) but got pretty close. let u know..
Could be to tall of helix causing it to shift out to quickly and not hold rpm under load. I had the same problem with a 43 degree helix under load. I had it set to 11,800 rpm holeshot and 11,600 rpm on top end on the flat with 11,300 rpm under load which is not bad. I want to hold 11,600 rpm under load on my sled with mods and it still pulls 11,300 rpm. I have a 39 degree helix in it now just need to do some more testing.
I am a biscuit at 300 lbs with all my gear so a 43 degree helix would work if it were a lighter rider. It pulls wicked with the 43 degree helix setup to top end. I may go with a multi angle helix like a 43/35 if I get the 39 degree to do what I want let you know.
