rxwhopper
using 9 tooth drvers also, anyone do this and what kind of clutching and gearing you guys recoment, any help would be great, oh ta anyone have any speed sensors for 9 tooth drivers?
putting 11/4 track on rx1 mountain
Yes, go to Mountain Performance web site, click on clutch/ power train, then go to gear & chain, then scroll down to the chart listing the ratio's for 8, 9 & 10 tooth drivers. Find the stock lists for you 8 tooth drivers and gears, then cross reference it to the 9 tooth for the correct gears at the same ratio. Also I would try the same clutch set-up you where using on the 8 tooth before changing. Hope this helps. 8)
