pdrmike
- Dec 13, 2005
- Berlin, WI / Ontonagon,MI
- 12 APEX'S 09 Venture GT
I just bought a 06 Attak with a Simons Turbo. It is blowing antifreeze out of coolant bottle on long passes. Ok, I understand this is a head gasket gone bad. My question is what is the next step. Can I just install 3 head gaskets, a shim kit and harder studs and be ok? Can I install these with the motor still in the sled, hopefully? (I only plan on running 8-12 lbs of boost) Thanks for the help. Mike
mulot30th
- Jul 7, 2007
- youtube.com
- 2023 thundercat
apex mountain crracing 174
apex blower 136 for asphalt racing
osp drag race sled (apex engine based)
Sometimes, you 'may' have to re surface the head too.
I had to do this one time but it detonated badly.
And yes, motor in the sled you can do it.
Ted Jannetty
- Nov 24, 2003
- Waterbury Ct.
- www.jannettyracing.com
pdrmike said:I just bought a 06 Attak with a Simons Turbo. It is blowing antifreeze out of coolant bottle on long passes. Ok, I understand this is a head gasket gone bad. My question is what is the next step. Can I just install 3 head gaskets, a shim kit and harder studs and be ok? Can I install these with the motor still in the sled, hopefully? (I only plan on running 8-12 lbs of boost) Thanks for the help. Mike
There are a lot of Unknowns at this point, Tear it down and see what you find, Carefully clean and check block and head for flatness.
Also Use a dial bore gauge to measure the bores for Bell Mouth, the top of the cylinders get bell mouthed from detonation which took out your head gasket.
If everything checks out OK, Just install 3 head gaskets, reuse the stock studs, torque to my specs and you should be good to go.
Ted.
- Sauk Prairie, WI
- www.ty4stroke.com
You sure your simply not overheating? Does the sled have a rear cooler?
pdrmike
- Dec 13, 2005
It does have a rear cooler, temp gauge was around 165-170 , and we have a lot of powder kicking up. Thanks for the help thus far, Mike
- Sauk Prairie, WI
- www.ty4stroke.com
Oh, then its most likely a head gasket. The bottle will start to overflow around 220.
tonykof
Okay, I don't want' to get your hopes up too high here but last year I had a weak radiator cap (Coolant bottle).
Replaced, no more problems.. Might be worth a shot..
good luck
Tony
good luck
Tony
