Embden
I was doing my 1st oil change this weekend. While going over the whole sled I came up with 2 questions. My secondary clutch (the larger set of sheaves) has a little bit of play in it. It slides about 1/16" back and forth on the shaft. Is this okay?? My other sled is tight. My second question is> where is the vbelt supposed sit between the secondary sheaves. On my older skidoos the top of the belt was supposed to sit FLUSH with the top of the sheaves.... on My Apex the belt is sitting approx 1/8" to 3/16" lower in the sheaves. The top speed on my GT is only about 115 mph on the speedo.... I hear of other guys seeing 125-128... could this be my problem??
