MaineiacZ06
I noticed the belt on my XTX was sitting slightly below the edge of the secondary. So I took it off and added shims to the 3 bolts. With the secondary off the sled, the belt sits just above the edge of the sheaves....right where I want it to.
However, when I hook the belt up to the primary...it sits even lower in the secondary now, indicating that the belt is too short?...pulling the secondary apart?
SO....how do I get the belt to sit above the secondary when hooked up to the primary?...and what is the belt deflection supposed to be? Is there a spec for it? Do I need a longer belt, or does the motor move? (slide the motor back to reduce the center to center measurement = more deflection?)
Any help is appreciated.....thanks.
ShootToThrill
Did you run the sled on a stand after you made the adjustment? If not try that because sometimes the belt will want to stay down a little until it gets spun around a few times. The deflection should be about 1 to 1.25 inches.
MaineiacZ06
Yup....I ran it for awhile on a stand after adjusting it...and it still sits lower in the secondary than it did before.cwcsrx700 said:Did you run the sled on a stand after you made the adjustment? If not try that because sometimes the belt will want to stay down a little until it gets spun around a few times. The deflection should be about 1 to 1.25 inches.
NyTrOMaNIaC
MaineiacZ06 said:Yup....I ran it for awhile on a stand after adjusting it...and it still sits lower in the secondary than it did before.cwcsrx700 said:Did you run the sled on a stand after you made the adjustment? If not try that because sometimes the belt will want to stay down a little until it gets spun around a few times. The deflection should be about 1 to 1.25 inches.
What kind of belt are you using, and how much use is on the belt ?
MaineiacZ06
NyTrOMaNIaC said:MaineiacZ06 said:Yup....I ran it for awhile on a stand after adjusting it...and it still sits lower in the secondary than it did before.cwcsrx700 said:Did you run the sled on a stand after you made the adjustment? If not try that because sometimes the belt will want to stay down a little until it gets spun around a few times. The deflection should be about 1 to 1.25 inches.
Stock belt... 1400 miles on it
RJH
it is best to set de-flection first and let the belt sit where it does.
If the belt is too short or too narrow..sitting high won't happen.
Adjust the deflection with the secondary.
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
On an jackstand the belt will not come all the way back up to the top usually.
Here is a good rule of thumb to use.
http://www.totallyamaha.com/snowmobiles/aaTECH/belts/beltdeflect.htm
MaineiacZ06
Srxspec said:On an jackstand the belt will not come all the way back up to the top usually.
Thanks for the info...I'll check it with the sled on the floor.
- 21K
