Question on clutching
Tom-RX1
Brandon Manitoba canada
Other than the spring what differences are there between the warrior clutching and the RX1 clutching . Going to try the white spring as i already have one just to see what it does . and would like to know if other things are different .
Tom-RX1
as far as i know the only difference is the roller diameter in the front clutch,they went bigger to get the rpm a little higher due to the extra traction,from my experience with the secondary settings any thing above 70 will kill top end with stock front clutch,the higher you go the less it will let it shift out on top,now have a team roller secondary that works well,theres my 2 cents
