rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Lakselv - 70N & 25E
- Norway
I have searched the site and the Internet but I can't find anything useful.
I'm in the works of getting my compression checked. I am running 10:1 pistons and 2 stock head gaskets giving a compression ratio of 9.13:1 according to the boost calculator.
My question is;
What compression in lbs will be normal with my 9.13:1 compression ratio?
My question is;
Thomas800
- Dec 17, 2004
- Fort St. John B.C. Canada
- www.snowmobiledragsters.com
Very hard to say. The the mechanical compression ratio will effect the cranking compression but.. The intake valve closing point will have a definite effect as well. Where do you have your intake cam set? You probably won't find a formula to give you an answer. I havent done your exact setup before, but I would venture a guess at about 135 to 140. Maybe someone that uses multiple gaskets will chime in.
Thomas800
- Dec 17, 2004
Oops. Just noticed where you live. 9.3 to 9.65 bar?
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Norway
My intake cams are set at stock setting.
When going with multiple head gaskets I had to grind the holes to move the intake cam back to stock position, all done according to mcxpress turbo install manual.
Anyone running 10:1 pistons and 0.54" headgasket did any compression testing? What have you seen measured in lbs?
Skydog
Hey buddy if they are all with in 10% you are good! Not to sure on a number but i would bet like 125 or so.
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Norway
Hi there Skydog - Thanks for your input
I'm asking this question because my friend has the same setup on his 2003 RX-1 that I have. He is a automotive mechanic and wanna make sure everything is OK inside his engine before running it with higher boost than the stock 10 lbs. This is his first yammi 4stroke ever, he just got it. He did a compression test today reading 116 lbs on the pto side cylinder. This was with a cold engine, the IC in place, throttle at WOT.
This would not give an accurate measurement I believe. Service manual tells you to warm up the engine prior to testing. WOT will not raise the carb slides, so I think he has to raise the slides manually as well, am I right?
When we have this Q figured out I will let him test mine as well
BTW Skydog - how's your apex running? any boost in the near future?
Jan-Ove
rxrider
Jan-Ove
rxrider
A
Anonymous
finally, got to test compression with engine hot today...
140-145 compression are my results with 9-1 shim
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Norway
mulot30th - thanks for your input.
Talked to my friend this afternoon, he will test again with warm engine, IC off, throtle at WOT and slides wide open. He said he would repeat the test with some oil added and do a second test.
rxrider
rxrider
TWIN TURBO
- Aug 30, 2005
- Chicago IL.
- www.powerbygns.com
Glad you asked was going to post the same question. 2006 Apex new with .062 head shim along with the 2 halfs of the stock gasket 9.3:1 wide open throttle gave me 155 lbs. across the board. Please keep in mind all compression gauges are not created equal 5lbs. more or less wouldn't surprise me at all. By the way thats a cold engine.
And a big yes to holding the slides open on a RX1 for the real number.
Friend of mine just put JE 10:1 pistons no shims in a RX1 and it gave him 165 lbs. on his gauge.
all above is with stock cam timing. Rolling the intake cam back to 114 c/L would drop compression about 15 lbs. tried it for fun.
A
Anonymous
TWIN TURBO said:Glad you asked was going to post the same question. 2006 Apex new with .062 head shim along with the 2 halfs of the stock gasket 9.3:1 wide open throttle gave me 155 lbs. across the board. Please keep in mind all compression gauges are not created equal 5lbs. more or less wouldn't surprise me at all. By the way thats a cold engine.
Friend of mine just put JE 10:1 pistons no shims in a RX1 and it gave him 150 lbs. on his gauge.
all above is with stock cam timing. Rolling the intake cam back to 114 c/L would drop compression about 15 lbs. tried it for fun.![]()
My intake cam is roller back 3.5 degree and exhaust cam is advanced about 3.5 degree
so my 140-145 compression is probably good according to your expermient.
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Norway
Thank you guys for your input,
I'll post :exc: the results when we have tested both his and my engine.
. I'll post :exc: the results when we have tested both his and my engine.
samrx1
rxrider said:I have searched the site and the Internet but I can't find anything useful.
My question is;
i am runniing....10/1 pistons and 2 heads gasket too....
my compression ..before start engine....145lb..
Skydog
Love the Apex BIG TIME!!! Going to just ride her stock TURN KEY!! HAHA I am going to keep the Rx1 turbo for my modded sled!
Skydog
Skydog
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Norway
I had my engine tested today. With a cold engine without IC or carbs in place, (it has not been cranked since the last trip in May) it tested as follows; cylinder 1=147 psi 2=130 psi 3=147 psi 4=159 psi.
I will make another test as soon I have her ready to ride. I assume readings will change when engine has been run a few miles.
My friends sled tested close to 145 across with a warm engine, IC off and slides wide open.
- 8K
