questions/ new to turbo and SC
timebomb
chase mills, ny
i've heard some say a turbo is better and some say a SC is better. which is it? is one cheaper than the other? which one is easier to install on your own? which brands are good ones to go with? any other usefull info. would be appreciated. thanks
Boost is Boost IMO both have there upsides and downfall's s/c in my opinion is an easier install ,Have had both, turbo has the ease of changing boost amount,where with the s/c you have to change pulley configuration to change boost. It is all preference. Gauranteed you will love either one. ;)!
This one has been debated for a few years now. Do a search on Turbo vs SC, there's a lot of info on the subject in here. Here are some links for starters
http://www.ty4stroke.com/viewtopic.php? ... percharger
and there are a lot more if you do a search. Please read thru this forum, all aspects of boost is covered whether Supercharged or Turbocharged, you'll find what you need to make a decision.
You guys are fast to respond, though I was out first. NOT.. :-) ... happy thanksgiving :-)
Yea you will love both!! I think that is WAY TRUE!!
Do some research (tons of posts and helpful information on all forms of boost in this forum) and do ALOT of reading and learn and understand both! The supercharger will be a shorter & easier install time. The turbocharger has easier boost adjusting. There are pro's and con's of each!
