msgt van
- Mar 21, 2014
- Kasota, MN
- 2008 Apex LTX
I wanted my seat to be slightly higher, so I performed a minor face lift....
First I removed the staples back to the storage area. I found a pair of fairly pointy diag cutters did the best job.
I pulled the cover back out of the way.
The foam then easily lifted up and away from the plastic pan.
I took some 1" styrofoam and cut it to fit the contour of the seat pan. Just on the top, not the sides...
I put the foam back into position, and pulled the cover down and around the pan, and re-stapled. Cover had plenty of excess fabric and stretch.
Doesn't look too bloated and sits where I want it. Took me less than one cocktail.
manotickmike
- Nov 14, 2015
- Manotick
- Apex
Nice! I could use a little more seat height... Now, off to research bar risers.
msgt van
- Mar 21, 2014
- Kasota, MN
- 2008 Apex LTX
I'm thinking a 2" riser would be swell.
What type of hard did you use and where did you get it?
msgt van
- Mar 21, 2014
- Kasota, MN
- 2008 Apex LTX
I found some 12" x 12" x 1" pieces back in our shipping department. If you're interested send me a pm with your address and I'll mail you a couple. I think I only used 2, broken in to pieces to fit. It's very dense, more so than beer cooler foam.
rangermike14
- Feb 19, 2015
- Byron Center, MI
- 2006 Apex
1998 SRX 700
You must not drink very fast!!!!
Haha!! Looks good.
Haha!! Looks good.Thanks Van for your help and foam.
Sent from my SM-N920V using Tapatalk
manotickmike
- Nov 14, 2015
- Manotick
- Apex
Gotta get off my "seat" and do this. Now that I got the bar risers on, I need to raise my butt.
msgt van
- Mar 21, 2014
- Kasota, MN
- 2008 Apex LTX
What risers did you go with?
msgt van
- Mar 21, 2014
- Kasota, MN
- 2008 Apex LTX
Looks great!Thanks Van for your help and foam.![]()
I have a Lake Effect Riser 6" with pivot. Superman Chris W. may have more. Check Ebay for Lake Effect.What risers did you go with?
gytr done
- Jan 8, 2015
- Rx1
That's a lot of work, i just put on a diaper! Great job
biffdotorg
- Dec 2, 2008
- Pelican Rapids, MN
- www.biff.org
- Apex XTX and Viper LTX SE
- www.biff.org
Nice work on the seat. If anything, if it keeps a guy from sinking into the stock seat, that's like adding 2" right there. I would bet this mod would be enough for many, and far cheaper than the WRP mod. You are not out anything for trying.I'm thinking a 2" riser would be swell.
What size staples did you use, or did you just match it up to what you pulled out I suppose?
I installed the Powermadd 2.5" pivot on my last two Apex and last Phazer. It's inexpensive and can be done without cable extensions. All it took was a re-route of the throttle cable under the bar, which can be detached at the fun-flipper, routed and re-attached in minutes. I put the pivot riser on top of the stock riser allowing me to keep my chrome ring around the base and stock clamp pad on top.
Good luck!
Ringold24
- Feb 13, 2015
- Ramsey MN
- 07 Yamaha Attak GT
I basically did the same thing adding 1.5" of polyethylene (6lb). Cover went back on pretty nice with the help of a heat gun. I used 1/4" heavy duty staples. A lot of them
I agree one inch of the Styrofoam is similar to adding two inches of foam. After ridding 535 miles on the seat, it was worth it.
I used some takie spray on the bottom of the pan edge only. I stretched the cover over tge edge to the outline of painters tape to mark exactly where the old cover was located. I used the same size staples. I still had the center of gravity feel on the sled.
- 7K
