Quick & Easy Starter Removal & Install
UP bushman
Munising, Michigan
Here is a video below to show an easy removal and installion of the starter on your Phazer. The main thing is to modify the tab off the bottom motor case with a grinder. Then the removal and install will be like in the video. Some say they can get it out without any disassembly of the front frame. I did not have any luck that way so this is what I came up with. With all the covers on it would take 20 minutes to have starter out with tab modified good luck.
http://www.youtube.com/watch?v=_wxJxXWn ... e=youtu.be
