dubweiser
installed the relocator today with a new steering post
question is : with the steering rod disconnected, so just the steering post bolted into the relocator....should the post just turn super easy, like touch it and it turns the other way or should there be some resistance there ?
everything is installed as per the instructions but its almost like the steering stops rub a little bit on the top of the lower block causing a bit of resistance
MNBlizzard
I put one on my '13 this fall. Resistance seems normal but you may want to double check you didn't over tighten anything. The resistance worked out on mine.
