skinz a arms with oft relocator
PoliticalMachine said:
sorenson1610 said:
Anybody try the weights yet?
Politicalmachine what hole are you running your swaybar mount in?
I just picked up some weights today they look like they will work great. I have the sway bar mounts in the middle hole.
Where you get them from? Post up some pictures when you have the installed
Oh ok I started off with mine there too but i moved to the front hole and noticed a huge difference with controling ski lift. Give it a try......i liked it much better ;)!
I got the weights at discount tire. I asked for a strip and they gave it to me for free. There is 10 or more weights on 1 strip. You just break off what you need. It looks like I'm going to have to double the weights up to get it where I need it. I will post some pictures tomorrow.
As for the sway bar, I haven't been able to ride this year at all. I will definitely try the first hole. I still cannot believe how bad this winter is. I thought surely this was gonna be a great winter, there is no way it could be worse than last year (wrong!). Might have to make the drive out west.
Here are the stick on tire weights.
Yeah I hear ya on the brutal winter.....as its been 40 degrees here for the last 3 days. Hope the UP snow machine starts kicking in here soon!
So how's the weights work, is just the one weight enough? Looks good
Either your tie rods are backwards or mine are. Mine don`t hit. the instructions wer very clear where the short end of the bend goes for clearance. Not the greatest instructions but that part was clear.
I don't know, mine where hitting last year as well so I have also put on stick on weights and it works great.
I probably shold keep track of this thread because I haven`t ridden on them yet. If I have the same problem I will try the weights.
