Winder_506
- Dec 21, 2012
- New Brunswick
- 2005 rx warrior
2013 apex xtx with woodys power up kit clutch work and mbrp pipe
Wanna run my max 20 tune sometimes on my ‘20 le. Have all the supporting mods to go with my dash reflash, question is to the racer guys out there, local shop sells VP race fuel, c-12,14 and 16. What’s the ratio race gas to 91 pump gas to get min 97octane to run race map thanks and marry Christmas the guys on here are great
I've been told if you mix 110 at 20% you will be good to go on max 20, but many on here with much experience will probably share expertise.
T-rav 27
- Apr 16, 2017
- Sudbury
- Srx 700 imp,1100 turbo, mcx apex
Best fuel to mix in there is c16 run about 25-30 % u should be safe thats what I run for testing
Fleecer
- Jun 13, 2014
- 2019 SRX
Figure everything on 10 gallon tank and find average. For example:
7.5 gallons x 91 octane = 682
2.5 gallons x 116 octane = 290
682 + 290 = 972 ÷ 10 = 97.2 octane
So you need 2.5 gallons of C116 with the rest of the tank full of 91 octane.
Using the same formula, if you put 3 gallons of C12 mixed with 7 gallons of 91, you would be at 96.7 octane.
stevewithOCD
Yamaha, Make me Come Back
- Jan 1, 2008
- Live CT Ride MAINE
- 900 R
2006 Apex RTX
8 gallons x 91 octane = 728
2 gallons x 116 octane = 232
728 + 232 = 960 ÷ 10 = 96 octane
So you need a little over 2 gallons of C116 with the rest of the tank full of 91 octane.
Can we rename you GASMAN?
FLEECER sounds like a guy that wears ugly sweaters.
GASMAN has PIZZAZZ!
DooZ
- Feb 26, 2007
- Minocqua, WI
- ZR9000RR
Doo 1200
Fleecer is right on. Also, Google octane calculator to brew up any mixture.
Long way https://www.sunocoracefuels.com/tech-article/mixing-fuels-calculating-octane
Short way http://www.bazellracefuels.com/Calcs/OC1.htm
lakercr
Tech Advisor
- Aug 12, 2003
- Winnipeg, Manitoba
- 2025 SRX
If you do a search under my user name with 'octane' as the keyword you'll find an Excel spreadsheet I wrote to calculate this.Wanna run my max 20 tune sometimes on my ‘20 le. Have all the supporting mods to go with my dash reflash, question is to the racer guys out there, local shop sells VP race fuel, c-12,14 and 16. What’s the ratio race gas to 91 pump gas to get min 97octane to run race map thanks and marry Christmas the guys on here are great
Winder_506
- Dec 21, 2012
- New Brunswick
- 2005 rx warrior
Thanks guys. I Google most everything but asked here first. Found what I was looking for now to fund it all at 220$ cad for 5 gallons of 116. Be a fun couple rides. Lol
- 10K
