Rage rear heat-ex fit Attak?
Sno Cat
Belknap County, NH
Will the rear heat-ex from a Rage directly fit the Attak? The p/n's for the rear frame stiffener are common between both sleds, my guess is yes.
Anyone install the Rage heat-ex on the Attak?
Easy install?
Thanks.
The Yamaha online microfiche does not list a rear heat exchanger for the Warrior, it only lists a rear crossover tube which leads me to believe the Warrior didn't have a rear heat-ex.
NY_Warrior:
BINGO! '05 Rage crossover tube p/n is the same as the '06 Attak. By the laws of dedcutive reasoning, one may conclude the rear heat-ex from an '06 Rage will directly fit an Attak.
Thanks for the help, Bro!
The 05 warrior's did not come with a rear heat exchanger, BUT yamaha did install some for the one's that had a overheating problem. My guess is that it was a rage part that was installed.
