80h4thephaze
Hey all,
Just wondering if anyone tried rail extensions and how they worked. I'm just wondering for in the future if it my be a good idea. Tell me what you think.
CROW
Also, does anyone besides TracksUSA make them? Can't believe how steep they're prices are now.
snomaniac
I got my extensions from hartman inc. Nice product and not too pricey my 128 extensions were $95. Great to work with too.
Boo Rad
X2 on Hartman's extensions. snomaniac, I just got the same pieces as you and they are great. Had the skid out already and took me about 35 min to do the install, that includes cleanup. I went with a 1 1/2" ripsaw cut down to 14", what track did you use?
80h4thephaze
sounds good i'l check it out.
80-- I went with the 136 Tracks USA ones, for the reason that they extend the Hifax all the way to the end. I'm not sure about the Hartman ones.
Either way you will love the longer track. I also cut dawn a track (cheeper )
snomaniac
I used a 1.375x13.5x128 firecat track unstudded, and love it. That 1.5 ripsaw should be insane. I think 128 should have been the standard track length on the phazer, it hooks up, and rides so much better than stock. What ski carbide combo are you using with that aggressive track? I've got usi spx skis with 8in shaper bars, and mine rails.Boo Rad said:X2 on Hartman's extensions. snomaniac, I just got the same pieces as you and they are great. Had the skid out already and took me about 35 min to do the install, that includes cleanup. I went with a 1 1/2" ripsaw cut down to 14", what track did you use?
Boo Rad
I used a 1.375x13.5x128 firecat track unstudded, and love it. That 1.5 ripsaw should be insane. I think 128 should have been the standard track length on the phazer, it hooks up, and rides so much better than stock. What ski carbide combo are you using with that aggressive track? I've got usi spx skis with 8in shaper bars, and mine rails. [/quote]
I like the track you are using, that was what I was going to get but got a deal on the ripsaw. The ski's on mine now are Sly Dog Powder hounds with 7.5" Shaper Bars.
Boo Rad
zook said:80-- I went with the 136 Tracks USA ones, for the reason that they extend the Hifax all the way to the end. I'm not sure about the Hartman ones.
The Hartman pieces do not come with hifax ext. but I believe he sells bolt on hifax ext. for the longer rail ext. If that makes any sense. The ext. for 121-128 are so short that there is no need for extending the hifax.
Kingsandman
Kingsandman
snomaniac
Boo Rad said:I used a 1.375x13.5x128 firecat track unstudded, and love it. That 1.5 ripsaw should be insane. I think 128 should have been the standard track length on the phazer, it hooks up, and rides so much better than stock. What ski carbide combo are you using with that aggressive track? I've got usi spx skis with 8in shaper bars, and mine rails.
I like the track you are using, that was what I was going to get but got a deal on the ripsaw. The ski's on mine now are Sly Dog Powder hounds with 7.5" Shaper Bars.[/quote]
Nice, my uncle runs sly dog trail with shapers on his phazer, he likes them alot. Your set up should rip.
snomaniac
If you contact hartman they will take the time to explain whatever you need to know. They are awesome. The owner talked with me for 15 minutes about the phazer just cause he wanted to make sure I got the most out of it. ( keeping the clutches and belt clean etc.) I appreciated that, instead of thanks for your money good bye.Boo Rad said:zook said:80-- I went with the 136 Tracks USA ones, for the reason that they extend the Hifax all the way to the end. I'm not sure about the Hartman ones.
08RTX
80h4thephaze,
I bought the tracksusa extensions with the 136" freeride track for my Phazer this spring. I planned to install it this summer, but I am now moving to Texas. I will not need this or my Phazer. Let me know if you are interested in the track and extensions.
Thanks,
Russ
(585)455-3366
Thanks,
Russ
(585)455-3366
prozac500
Kingsandman said:2 1/4" x 153" CR Racing extensions
Where do you ride and do you like the sled that long I am asking because I am thinking about going 144.
