Grimm
bump for a reminder of pics
Super Sled
- Feb 25, 2009
- Summit X
I moved over to 2speeds from these. The 'Rats were just not trail friendly enough....
yukon yamaha
- Jan 30, 2008
- WHITEHORSE, YUKON CANADA
- 2008 nytro custom! 2014 viper custom
SORRY about the picts guys lost the card on the trail and have not had a chance to get back into the machine..... I have been clutching our new 270 mtx and it has been a handful! but i think i have it nailed down! Good old 8BU weight always come through in a pinch
loudelectronics
Ever thought of trying the rats for the polaris?
I am using the rats with 2.5 balls and black spring. Secondary is stock. With hindle exhaust I am pulling 9300 RPM. In the mountains i would like to get the revs up at it was hitting 7400. Mine did not come with lighter balls though.
Before exhaust and 20 tooth gear it was 8400 Like you guys. Wonder what the stock spring would do in the primary. No snow to try it out.
BADSLED
- May 13, 2004
- Syracuse, NY
- 2012 Nytro MC Xpress 270
2011 Apex SE
2021 Sidewinder LTX SE - SOLD
Super Sled said:I moved over to 2speeds from these. The 'Rats were just not trail friendly enough....
x2 Good move.. I could not agree more..
zx4ever
- Apr 14, 2011
- Northern BC canada
- 08 nytro ty4stroke customized
any pictures or updates on this as i have a set and have only had a hour to test and i am not even close to the right rpms but i am going out this weekend for 3 days and should get a chance to try them
yukon yamaha
- Jan 30, 2008
Guys i gave up on the RAT weights, i could not get them to work right, i tested and did everything i could! I went back to 8bu weight and it is much much stronger all the way through the rpm
loudelectronics
What's the 8bu weight?
loudelectronics said:What's the 8bu weight?
Factory Yamaha weights
8BU-00..used in 95-96 VMAX 800
8BU-10..used in 97 VMAX 800
loudelectronics
What's special about them?
aggressive profiles....good for drag racing if you can get them to work. If you go to the TY main page, go to the technical pages, then to clutching, then weights...you'll find pics of the weights, showing their profiles.
yukon yamaha
- Jan 30, 2008
8bu17605,empty, w/ 14.5 rollers, 22/40 gearing 1.81ratio, pink/silver/pink primary white spring at 90 degrees.... engaugement at 4200 peaks at 9000 and backs down to 8800
BADSLED
- May 13, 2004
- Syracuse, NY
2011 Apex SE
yukon yamaha said:8bu17605,empty, w/ 14.5 rollers, 22/40 gearing 1.81ratio, pink/silver/pink primary white spring at 90 degrees.... engaugement at 4200 peaks at 9000 and backs down to 8800
White secondary @90? How many people does it take to twist the helix onto the secondary? Why wouldn't you control the shift rate with less helix angle rather then twisting it so much?
yukon yamaha
- Jan 30, 2008
It only takes me to put it on, i was running an epi purple turbo spring for a while with the rat weights and that took two guys.... With the 39 degree helix it alows me to get a very hard hit out of the hole and keep pulling the tall gearing at the top..... I tried a 41 degree helix and i was not very happy with the launch, I have tried 39,41,43,45, and a few multi's and the best one still is the 39..... I treat this sled like a race sled, the harder it hits out of the hole and quicker the responce the better, if i had a 37 helix i would try that as well..... super snappy off the bottom
