a fiend of mine bought a 08 phazer rtx.i can hear a ratteling sound when let go of the gas.its hard to describe the sound .Can it be noise from an icy tunnel?or something that is loose. thanks
Clutch noise?
QUADSCRIB
cannondale27 said:Clutch noise?
My clutch rattles a little at idle. From what I read this is somewhat normal with Yamis?
it is not clutchnoise.it happens under deceleration,ratteling and scraping sound. thanks
woolyviper
- Mar 24, 2006
- hibbing,mn
- 2009 Yamaha Phazer RTX
track ratchet on decel.
the sled has no slip drivers and a freeride track.could it be the no slip drivers that makes this noise? thanks
Try exhaust clamps on header and possible heat shield? you can check both at same time. I had same thing and thats what it was for me.
barnstormer
Try tapping the throttle it will help the pulleys to back shift. That makes a weird noise on my sled.
