mulot30th
- Jul 7, 2007
- youtube.com
- 2023 thundercat
apex mountain crracing 174
apex blower 136 for asphalt racing
osp drag race sled (apex engine based)
On my turbo apex.
once past 10300 rpm, seems like it hit rev limiter/ sputter ....
Did this on dyno too.
On laptop computer connected to rb3, I can see rpm value jumping EVERYWHERE once it hits 10300-10400 rpm...
will show anywhere between 5000 to 11900 or so rpm on laptop while reading pretty still at 10300-10500 rpm on tach.
I tried moving rev limiter up 1000 rpm more... does not change anything, same problem happen at same rpm.
What is happening here?
mulot30th
- Jul 7, 2007
- youtube.com
- 2023 thundercat
Please note I also have a MSD launch master (connected AFTER rb3) on this... can this mess rb3 rpm read?
thamax
check the connections for moisture and everyone said to put dielectric grease i actually had better luck with anti sieze plus its a better conducter and rust preventer. what version are your running 4.7 is the latest out there with the ignition update
mulot30th
- Jul 7, 2007
- youtube.com
- 2023 thundercat
I will have to check the version not sure.
Turbor
- Apr 16, 2008
- mirabel,quebec,canada
- sidewinder
you have 4.7 muloth, when dave from powderlites did your update last year in b.c, thats the version he put in.
gouldsjett1
rb3
I have a launch master and rb3 with no issues like you describe. Good luck finding the gremlin.
mulot30th
- Jul 7, 2007
- youtube.com
- 2023 thundercat
This issue is for real, sound exactly same as hitting reve limiter, but nowhere near engine rpm as it should be and rb3 jumps everhwhere in the rpm column while this happens.
Not too funny, and have no clue what is that.
Turbor
- Apr 16, 2008
- sidewinder
mulot30th said:Not too funny.
no?
Might have to clear RB3 and reinstall software back on. Look at all fittings!
gouldsjett1
rb3
Have you tried adjusting max voltage setting?
thamax
well did u switch harness for the update or modify your current harness? cause that happened to me last season when a solder joint broke and ruined a day of riding if the problem something new most likely a hardware problem most of the time
mulot30th
- Jul 7, 2007
- youtube.com
- 2023 thundercat
I will have to check harness... have to be something in there OR rb3 itself.
Vmin vMax are okay.. but this is unrelated to rpm reading anyway...
