TBird
- Dec 25, 2004
- North of Sweden
- Sweden
- Yamaha Viper and Yamaha Nypex
MulotTurbo said:TBird said:And i suppose that with the Lite software i can't change the stutter rpm, i can't find any menu that says "rpm hold function".
I don't think you can edit much at all with the lite software! (10% fuel / spark values I think).
BTW I figured out how to make it work.
I just made a quick 'stutter' by using 2nd maps timing/injections and rpm hold function together:
Been able to make a good 1-2feet long flame out the exhaust... so that should be good to build some boost off the line![]()
Thanks, i were afraid of that :-(.
Coool, i want to throw flames to
Does anyone here know at which rpm "default" stutter is from Dave?
mulot30th
- Jul 7, 2007
- youtube.com
- 2023 thundercat
apex mountain crracing 174
apex blower 136 for asphalt racing
osp drag race sled (apex engine based)
TBird said:MulotTurbo said:TBird said:And i suppose that with the Lite software i can't change the stutter rpm, i can't find any menu that says "rpm hold function".
Coool, i want to throw flames to![]()
4474 rpm is I remember
But.... the default stutte will just do nothing to spool up that turbo
I've played quite a bit before finding a good combination.
Now I can get it to stutter while sending big explosions in the exhaust... this should spool that turbo up when I set up my apex
Adrenaline Addiction
I'm looking to run the stutter on my Apex grass dragging, has anyone burnt the track with the tunnel dump exhaust ?
mulot30th
- Jul 7, 2007
- youtube.com
- 2023 thundercat
Adrenaline Addiction said:I'm looking to run the stutter on my Apex grass dragging, has anyone burnt the track with the tunnel dump exhaust ?
You dont need to hold it too long... 2 seconds should be enough if set up properly
