Mercer5
- May 31, 2007
- Wales WI
- 2014 Viper, 2001 SRX, 1990 Sno Scoot, Kitty Cat
Hey guys, I am new to forum as member. I have an 06 RTX and the check engine light came on numerous times last year with temp light. Yes i did find coolant to be 100% glycol so I changed that but it still happens. How do I find out what codes it flashed?
What shoudl I start with? I read all the FAQ's
Jim
Jim
MCApex44
- Mar 30, 2006
- Western New York, Chautauqua County
- 2014 Viper RTX SE (sold)
Mercer5
- May 31, 2007
- Wales WI
So how do I get the codes to show up on display?
MCApex44
- Mar 30, 2006
Mercer5 said:So how do I get the codes to show up on display?
Click on 'download'.
Mercer5
- May 31, 2007
- Wales WI
I printed that , but where do I see what codes come up on display?
Swiss Sledder
- Apr 18, 2003
- www.mi5.gov.uk
Do you mean "where on the gauge pod are they displayed?" If so, they are on the right side if I remember right. If they appear, you really cannot miss them.
1CrazySledder
- Aug 11, 2005
- Cartersville, GA.
- None, looking now!
-Turn the main switch to "OFF" and set the engine kill switch to "ON".
-Simultaneously press and hold the "SELECT" and "RESET" buttons for 8 sec.
-After selecting "dl", Simultaneously press and hold "SELECT and "RESET" for 2 or more seconds.
You use the "SELECT" and "RESET" buttons to advance or go back through the code number. They are 01 through 70.
Turn the main switch to "OFF" to cancel this and put the gauge back to normal operation.
06apexrtx
if you had a code it would come up on the speedo gauge and show the number or to check all the codes as 1crazy has said do that check.
Mercer5
- May 31, 2007
- Wales WI
Thanks 1crazy, thats exactly what I was looking for.
Mercer5
- May 31, 2007
- Wales WI
I am working on it right now and I can't get anything to happen, when I do what you say all that changes is the clock reset..................hmmmmm
HELP !!!
HELP !!!
