GER-
Before you go buying flaps, burp the machine, and make sure the coolant is a proper mix, since lots of these sleds came from the factory with the wrong mix...100% antifreeze. Then consider the add on exchanger, which brings the temp down considerably, and finally put some water wetter or similar into the mix. Bet the whole matter goes away.
