05RXW
- Apr 22, 2011
- Caledonia, MI
- www.bigboytoydoc.com
Ok i have been looking around on the site for awhile an im seeing a trend. These sleds need more cooling for low snow conditions. An what i have seen is two options, an apex radiator by the brake, or a rear heat exchanger. I would rather do the rear heat exchanger, but i cant find anything for info. If someone could point in the right direction, i would be greatly appreciative.
jsjk-4-stroke
call kevin at port yamaha he should have them , i had to put them on both rx1,s & vector they work great.
Mighty
- Apr 17, 2003
- Grand Ledge Michigan USA!
- 22 Mach Z
23 Sidewinder SRX
Have done both and both work well. But the radiatior w/fan works better in all conditions; Setting, low snow, hard pack and icy conditions. Where the rear exchanger only helps while moving and with snow hitting it.
05RXW
- Apr 22, 2011
- Caledonia, MI
ok ill do that. but i just did some looking on the parts fiche, an it looks like the apex mt have the extra cooler in the back. Im wondering if that is what he is going to sell me?
Mighty
- Apr 17, 2003
- 22 Mach Z
23 Sidewinder SRX
Worth considering:
http://www.ty4stroke.com/viewtopic.php?t=106229
05RXW
- Apr 22, 2011
- Caledonia, MI
OK, i sent you a PM but thanks for the Info
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
I have a 121" rear cooler. $86 shipped.
05RXW
- Apr 22, 2011
- Caledonia, MI
hibshman25 said:I have a 121" rear cooler. $86 shipped.
can you put up a picture for me so i can see what i looks like.
Mighty
- Apr 17, 2003
- 22 Mach Z
23 Sidewinder SRX
No offense hibshman25, but if you are going to install a rear cooler install the mountain cooler. It's like 5 times bigger than the 121
I've put the rear heat exchanger in 3 Rx1's. It solved all my problems. Still riding 2 of them. It's an easy install.
05RXW
- Apr 22, 2011
- Caledonia, MI
ok so i just looked at the mountain rear cooler, an they want $500.00 for the dam thing..... that kinda makes up my mind for a radiator an fan...
SMOKNZ
Port sells them for $315
05RXW
- Apr 22, 2011
- Caledonia, MI
well i went with the Apex radiator from Mighty, so we will see what it looks like when it gets here.
thanks
thanks
Fourcam281
I just put one on my RX1 a week ago. Pretty easy job.
jtman04401
I installed a radiator and fan on one of my RX1's last season. It was pretty easy. I had it hitched up to a toggle switch last year but this fall I went to Napa and purchased a sending unit to make the fan come on when it gets to 220 deg. Ill see how that works as soon as we get any amount of snow around here.
