Rear shock on attak
ontario
Canada
2006 apex attak and 2001 srx
i just took my shock out of my 06 attak because it would drop about 5-6" if I lift the back up and drop it, the sled has just over 6000miles are these common to go? The sled was on the dollies if that matters
Does anyone know how many psi's of nitrogen is in that shock for a 136" suspension?
Don't check suspension on dollies. It messes it up sometimes. Have it on the ground, and check for proper sag, and then determine if the shock needs a rebuild. But to you answer your question, yes, they don't last forever and need servicing once and a while. How you ride impacts how often.
If never serviced (oil change and seal replacement) it's high time it had one imo.
Would not let one go more than 3 seasons without a refresh.
A good shock guy is in Drayton ON, if you need details, PM me.
Robs06, were about in Ontario, Excalibur is doing shocks now in Thunder Bay, around 45$
There's a guy in port colborne that'll do it, thanks guys
