AttakDog
I pulled the rear upper idler wheels on my 05 RX1 and these don't have replaceable bearings. Does the 06 or newer Apex's have a wheel with a replaceable bearing or is there a wheel that I can get that does have the bearing and wheel separate?
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
yes the apex has replaceable 6205 bearings in the LARGE 7" UPPER wheels which have 25mm ID Bearings.
GUIDE, WHEEL
8CR-47550-00-00
$20.12
I just ordered two new GUIDE wheels and they come with bearings.
also the rear INNER axle 7" wheel(i have two cause i run a 4 wheel axle) are also replaceable bearings.....just 20mm ID instead of 25mm ID.....the outers DID NOT have replaceable though.
Dan
GUIDE, WHEEL
8CR-47550-00-00
$20.12
Dan
AttakDog
Thanks Dan your bearing/wheel knowledge and posts are second to none. Also put the rear shock protection tube in like the pics you posted. The wife's 05 RX1 is now like a 2010 as far as durability goes-maybe even better!
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
AttakDog said:Thanks Dan your bearing/wheel knowledge and posts are second to none. Also put the rear shock protection tube in like the pics you posted. The wife's 05 RX1 is now like a 2010 as far as durability goes-maybe even better!
