Rear Upper Shaft Play?
Panterawill
I'm reinstalling my rear skid components after having the skid parts reworked by Half-Baked (awesome job, btw). I have installed the new bushing, 2 washers, wheel then the white plastic sleeve over the shaft. The white sleeves are flush to the outside of the shaft.
I can still move the wheels/shaft side to side about 2-3 mm. I know I've pressed the wheels on fully. Is this normal?
Will
Thanks.
Also, where can I find the model # of my sleds? It's not on the side of the sleds ( I have an 06 RTX and an 06 ER). RX10RTL,RL,RTRL...??
I'm looking at 700 pages of the service manual and see diagrams of different models. I'm not sure what parts of the service manual I should keep/refer to.
Panterawill said:
Thanks.
to.
RX10RTL
They are all the same the only thing is chain case.
The manual shows many different views that are not like miy rear skid. For example, sect 2 page 16
Someone once sent me a link to a TY page that had a number of common task links that showed the past threads. I cant seam to find it.
