phzmtnlite
I honestly have looked around this site for a complete list of recalls and/or bullitens on my Phazer Mtn Lite. My dealer has me slightly concerned as to what exactly they are. i would rather find out from a different source. Sorry if I have missed this and it is redundant. If it is, just shoot me in the right dirrection. Thanks!
Cody
- Feb 28, 2008
For the MTX's/Mountain lites
Handle bar warmers.
Steering malfunctions.
Reverse problems.
Those are some of the main ones.
Handle bar warmers.
Reverse problems.
nightsniper
Cody said:For the MTX's/Mountain lites
Handle bar warmers.
Reverse problems.
what was wrong with the warmers?
jlparker77
they left a harness out, so if your warmers work at all, then it either doesn't need done or has been done.
nightsniper
jlparker77 said:they left a harness out, so if your warmers work at all, then it either doesn't need done or has been done.
ok, thanks.
tapex_07
- Feb 15, 2009
'07 Apex RTX SC2 MPI 128x1
What years do they pertain to?
Hand warmer harness kit part number 90891-50150-00.
For the reverse problem get belt number 8GK-17641-10 and shim number 90201-345G2
ThatOneGuy
got some info from my dealer on the hand warmer issue, since mine have never worked at all... They showed me the paper work they got and it says its only for the 08 phazers? But he copied off some of the papers and the handwarmer specs for me to take. My handwarmers checked out with the multi meter so they should be good. The wire harness kit looks like all it is, is wiring the warmers in series instead of beign paralell. Mabye I got that switched around can't remember which is which exactly but you get the idea. I think I'm just gona order the harness, pretty sure its like $10 or so anyone else confirm that I'm looking at the right stuff?
Joe
Joe
ThatOneGuy
NKSALES said:Hand warmer harness kit part number 90891-50150-00.
Didn't see this right away, but thats the part number the papers the dealer gave me has. Also says dealer cost 10.32 and says service affects all units regardless of warranty status! Oh ya the other papers say the warmers should check out at 6.12-7.48 ohms.
ThatOneGuy
heres the diagram that the paper work shows to help anyone understand what it is, ordered it from the dealer and should be comming in early this week.
ThatOneGuy
the wire harness worked!!! I had to turn my warmers down about halfway last night for the first time ever! My sled now has great handwarmers, it just sucks that I had to pay 10 bucks to fix yamahas problem...
- 8K
