steveg_nh
- Jul 23, 2017
- Southern NH
- 2007 Attak
So you cut the actual dial plate itself vs the thicker plate it attaches to?
Sounds good! Either wayou already have the RA plate which needs two sides trimmed with mounting holes already there. Cut it to fit and if you don't like the fit, use your aluminum patch, just a suggestion.
Not following this part. "My way" is to just cut the aluminum sheet so it's just larger than the opening in the tunnel reinforcement, so all edges are hidden. This is so thin, as long as rigidity isn't an issue when covering the hole, it won't raise the tunnel reinforcement plate to any noticeable level.and if it is an epic fail then just do your way...
