Removing Front Heat Xchngr
No, you need to remove the rivets (a lot of them), the drive shaft, chain case and secondary. Then there is a long bolt that runs from the secondary through the motor (or by it) and you will see the nut just to the right of where the chain case was that holds it.
Just put min back in the other day.
I removed the motor, but a buddy removed his skid to get his out. Either way it's a lot of work... Lots of rivets.
