yama eric
- Feb 1, 2016
- maine
- 2004 Rx-Warrior
2004 rx warrior front heat exchanger replacement does motor have to come out
Its a big job but it dont have to come out but you will have to remove the lower bulkhead pan... its not easy. I have seen the welded or repaired on the sled.
yama eric
- Feb 1, 2016
- maine
- 2004 Rx-Warrior
Welder said oils from coolant cause pin holes in aluminum. He said he has never had good luck welding them.
Whats the lower bulkhead pan?
Indy
save yourself money, hassle and time . . . JB Weld it, works great and lasts forever.
I have had piles of them welded..maybe hes not a great welder. Pan is the bottom part of the bulk head thats riveted in about 25 to 30 rivets that hold the oil filter inspection plate.. as I said this is no easy task.
yama eric
- Feb 1, 2016
- maine
- 2004 Rx-Warrior
no kidding thanks for infoI have had piles of them welded..maybe hes not a great welder. Pan is the bottom part of the bulk head thats riveted in about 25 to 30 rivets that hold the oil filter inspection plate.. as I said this is no easy task.
tedgoesfast
ive sent out over ten had welded on sled no issues i guess i have an exceptional welder
