Hoxtongue
- Jan 23, 2014
- 2006 Yamaha Apex RTX
Quick question, do I have to pull the skid to remove the monoshock on a 2006 Apex RTX?
JROCK
- Oct 25, 2007
- Ottawa, Ontario
- 2006 Yamaha Apex GT
No! back off spring adjustment remove two shock bolts and adjustment cable.
You can remove the shock without removing the skid.
First compress the spring with a spring compresser.
Remove C-clip that holds spring adjuster. Now with the pressure off the shock you can remove RA cable and the bolts for the shock.
Mile9c1
Where's a good place to buy the spring compressor tool?
Mile9c1 said:Where's a good place to buy the spring compressor tool?
I use strut spring compressors.. Napa or from Auto Zone
Teamblue4
- Feb 20, 2008
- Il.
- 2012 Apex XTX
2013 Apex SE
2014 Apex SE
2014 Apex XTX
Take bolt out of transfer rod, lift rear of sled and unbolt the shock.
Big Daddy SRX
- Feb 24, 2006
- Reese, Michigan
- 2018 Sidewinder LTXDX,2014 SR Viper, 2012 Vector LTX, 2011 Apex XTX,
- Reese, Michigan
- AOL
- reesetrailer@aol.com
Best way I found to compress mono spring is to use 1 1/4"rachet straps. I bought two of them at Home Depot, they must be the "endless loop" style, this means NO HOOKS, made by Keeper Products. Loop the webbing down the inside of the spring from top to bottom and then up the outside and hook the loop to the rachet. Repeat on opposite side of the same spring. Draw both rachets up evenly, a little at a time. I was able to even pull a "Big Boy" spring together very easily. I tried three different strut spring tools for cars but they did not work very good, these rachets work great and will not scratch the springs. You can use them to remove or install shock springs. I found a video on this on You Tube.
