removing stock muffler and heat shield
savan2000
Hamilton,Ontario
im trying to remove the muffler. whats the easiest way to do this.got the clamp loose on the header.just tap the muffler with a rubber hammer?
I found it easiest to jam a screwdriver in between the slots on the muffler and twist. This loosens the clamp to the point that I didn't need to use a hammer.
I had someone pull and gently hit it with a rubber mallet like you said,I had mine off many times. This words fine for me
