Reoccurring code 20
yamahatd
mass
I continue to have code 20 appear on and off when I start my 07 RTX. I have been through the entire air box. Checking all connections and sensors. I can't figure this out.
Anyone else have this poblem? I know what the code means, I just can't get to go away permently. Any help would be appreciated.
Thanks :Rockon:
Is it only my antivirus that...
alerts when i try to download this document?
It says the file contains a worm of some kind.
Hopefully my antivirus is wrong, but anyway
i feel obligated to inform you guys anyway.
// Snoopy
Like I mentioned. I am aware of what the code is, I just don't know how to fix the problem. Is It a Sensor or connection? I'm at a lost here. I have completly taken the air box apart and reassembled it with all sensors connected.
I need some trouble shooting. Any help, greatly appreciated.
:rocks:
:rocks:
The air intake pressure sensor is in the sled nose on the bracket that holds the electrical module. It (I believe) is right on the goldish metal bracket and is black plastic with a long slender tip.
The sensor on the side of the box is the air temp sensor inside the box. The 20 code means the computer can't read the barometric pressure and adjust for Milibars. Try the barometer readout on your dash and see if it is reading anything.
Thanks for that tip on the location of the sensor lead in the hood. I'll check that.
I looked for the link to down load the shop manual, but could not find it. I thought it might have some trouble shooting ideas in it.
Thanks again for all the help :rocks:
was this corrected as i have a code 20 as well??? It was -35 C i started it to move into the garage and got the code. Will it affect how the sled opperates????
