As one can expect I am not in the financial position I was a year ago, so I am trying to save a little money, so I wil pose the following questions.
1) Roughly how much to have A Arms replaced by dealer?? 1 side
2) Is it a job that a novice mechanic could do by himself? Does not look that difficult. Just make sure tourqued to the proper spces, which I ran accross doing a search.
Thanks,
Chris
Thanks,
Chris
Not all tht hard. Just unbolt and replace it then rebolt it back together. While you have it off you could install some grese zerk in them.
yukonranger
Yep it's not a hard job. I have a set of a-arms and spindles off of a 08 mtx with greasable ball joints installed if you are interested.
phzmtnlite
I did it and was so easy, actually I bent mine after 225 miles. I put the right ski in a culvert and spun it around and fliped over. Bent both upper and lower, bent shock, messed it up good, Took it all apart, both sides. I put the bent parts in a vise and spent alot of time to get back into shape, it was very hard to do. I now have 3300 miles and you cannot notice or feel it in any way. Steers straight as an arrow with no sighs of damage.
- 8K
