Tmzwinder
- Oct 13, 2023
- Dane, Wisconsin
- 2023 Sidewinder XTX LE
Simplespeed
- Jan 8, 2022
- 1191 Sauk Lane , Saginaw, Mi. 48638
- 2006 Apex , 2017 Sidewinder LTX -LE
Yes thats the one I purchased also but now there are some others that work as well .. I like the one were using…I added the Iso-vibe riser to my 23 XTX. Definitely feel it helped some. The brand is Grip n Rip, called iso-vibe riser.
stgdz
- Mar 27, 2021
- Buffalo MN
I put that riser on my 800 zuke and it knocked down the vibes like no other. The problem with it is that the bars rotate a lot. I would accelerate hard and the bars would rotate towards the back.
I have flex bars on my ATV and I can tighten them down to prevent this but these don't seem to have that option.
Simplespeed
- Jan 8, 2022
Thats interesting cause I have not had any issues using this product.. I would like to add that I do relax my hands and arms and do not hold on tight but always in a relaxed state… Are you hanging on with a death grip and causing the movement ??? Or do you have a situation where you got something installed where you can not tighten to proper torque specs.. The only movement I have noticed is the small amount of movement in the steering bar that most all sleds have….
Clintww
- Mar 6, 2022
- Central MN
- 2001 SXR. 2005 RX1. 2017 Sidewinder
- MN
When you guys add the riser, are you also replacing the brake hose? It seems to short now as is.
Simplespeed
- Jan 8, 2022
No it only added 2” higher than stock, so I just pulled some extra brake line from inside motor compartment…
stgdz
- Mar 27, 2021
- Buffalo MN
torqued mine to spec.Thats interesting cause I have not had any issues using this product.. I would like to add that I do relax my hands and arms and do not hold on tight but always in a relaxed state… Are you hanging on with a death grip and causing the movement ??? Or do you have a situation where you got something installed where you can not tighten to proper torque specs.. The only movement I have noticed is the small amount of movement in the steering bar that most all sleds have….
They do move a lot more than my flexx bars. I will see if I can get a video of it sometime.
- Poll
- 66K
