RTX
- Mar 31, 2005
- massachusetts / maine
- 2014 viper rtx
2006 apex rtx
i like the concept of the trihub, but i dont like that the bearings are not replacable.
After reading a post a while back about making the bearings replacable on a-chat i decided to give it a shot.
Plus im wicked cheap and have full access to a machine shop with every tool and machine you can imagine
Before i get too far, this mod requires some skill with tools. If you dont have access to the proper tools or cant fabricate the things you need to do this i suggest not attempting this modification.
Disassemble the wheels from eachother, remove them from the axle.
Center one of the trihub wheels in a drill press with the long attachment arms facing up.
I did this by securing the wheel in a vise. I then used a 20 mm drill bit in the drill press chuck and aligned the bit through the center hole on the bearing. If you dont have a 20 mm drill, wrap some tape around a 3/4 drill bit till it slips freely into the bearing. It does not have to be perfect. Close will do.
Once you have the chuck centered with the wheel, secure the vise to the drill press. Once secure, recheck your alignment. If it is ok, install a hole saw in the drill press.
The original info i read stated to use a 1-3/4 hole saw but i used a 1-5/8 hole saw because my experience with holesaws is that they dont cut perfectly round. They usually cut a little large. More about this later.
Slowly and gently procede to cut the outside plastic with the hole saw. You need to go about .100-.125 deep.
You will eventually hit a molded in washer before you hit the bearing. Stop cutting when you hit the washer.
Remove the wheel from the drill press vise.
Use a socket to drive the bearing out of the trihub. I used an actual press but use what you have. It might give you a little fight but it will eventually press out
The bearing and the molded in washer will be removed. Both of these get thrown away.
You can now see the inside of the trihub minus the bearing. You will see on the back side (opposite of where you just cut) there is metal washer molded into the trihub, this is what your new bearing will be pressed against.Clean up all the plastic using a file, deburring tool, razor blade, what ever you have to make a nice clean edge where you just cut with the saw.
Install a new bearing pressing it down till it butts up to the molded in washer.
At this point you should be able to see there is a groove located in the wheel above the bearing you just installed. This groove is from the molded in washer you just removed. If you did everything correct your internal retaining ring will fit perfectly in this groove
Install a 1-11/16 internal retaining ring into the groove. If it does not fit well. Heat it gently with a torch and install it in the groove. The hot retaining ring will cut its own groove. You dont need a ton of heat. Too much heat will destroy the retaining ring.
On my wheels the retaining ring fit great on 1 wheel, not so great on the other.
I used a bearing heater to heat the retaining ring and slid it into the groove while turning it to enlarge the groove.
While this might sound pretty invoved, Overall the entire project took just over an hour. Im very happy with the results but was unable to take pictures because i did this at work and we have a no camera/cell phone policy
raptordan
- Jul 5, 2004
- Barrie ont.
- 2017 sidewinder ltx le
Great right up, I did the same with mine this year but used a lathe and machined it out with a boring bar.
RTX
- Mar 31, 2005
- 2014 viper rtx
2006 apex rtx
Yup, i thought about going that route but being at work i have a lot of eyes on me. Lol
This was the easiest route for me because nobody pays any attention to me using a drill press, as soon as a turn on a milling machine or lathe theres 1o guys with nothing to do watching and asking questions. Lol
Did you stick with the 6004 bearing?
Im giving some serious thought to buying a used trihub and throwing it in the lathe and machining the bore to fit a 6204 bearing.
6004= 20 x 42 x 12
6204 = 20 x 47 x 14
I know the 47 mm od wont be an issue but i am concerned there wont be much meat left on the width.
The 6204 has a higher load rating and In my opinion will hold up better to the abuse. Plus they cost less.
My sled only had 1800 miles on it and the trihub bearings were already turning rough
new rob
- Oct 18, 2009
- peterborough ontario
- Viper rtx
I hear newer viper tri hubs have replaceable bearings can anyone confirm this????
RTX
- Mar 31, 2005
- 2014 viper rtx
2006 apex rtx
According to the yamaha microfiche 2014 and 2015 have molded in non replacable bearings.
I dont see 2016 microfiche published yet
BTbt
- Apr 11, 2005
- Kettleby, Ontario
- 2017 Sidewinder LTX LE
2016 Arctic Cat parts microfiche on Browns Leisure World shows replaceable tri hub bearings
new rob
- Oct 18, 2009
- Viper rtx
Cost ??? I hear around $40 ??? if so I don't mine changing bearings once a year usually change idler bearings anyways
yamadoo
- Jun 3, 2003
10 Vector LTX Blue 9kmiles
11 Venture GT 4k miles
86 SnoScoot(2) for grand kids
40$ for bearings ? I wonder what the new tri hub with replaceable bearings goes for?
yamadoo
- Jun 3, 2003
Later it's 31 $ for the "idler" wheel on cat parts, hope that includes the bearings can't tell. But since it has a new part number I assume it's the new one with replaceable bearings.
Even if not I will likely replace the assembly if or when bearings rolls rough.
new rob
- Oct 18, 2009
- Viper rtx
$40 tri hub ???
yamadoo
- Jun 3, 2003
This is the XF 141 rear axle center system I think that is what we are referring to as tri hub
canadianhunter
Do the not all have the trihub rear axle ?
RTX
- Mar 31, 2005
- 2014 viper rtx
2006 apex rtx
Trihub is 2 pieces.and it is on every viper.
Stating that it is 31 bucks is a little misleading. you actually need to buy 2 of them with tax and shipping so its more like $70+
At the end of the day if people want to buy new ones because they do not have replacable bearings in theirs then thats their choice im fine with that.
The purpose behind this post is to explain to guys that it is possible and relatively easy to fix thier existing trihubs as opposed to buying a new one.
I bought a hid headlight kit with the money i saved fixing the trihub.
fasteddie15x
- Jan 20, 2014
Nkroeger80
Hi, in your picture you have a new axle. And new wheels. The wheels don't look like the have the molded cones to separate the wheels and the axle doesn't look like it has a larger diameter to keep them separated. Just wondering if they are direct replacements for the OEM 2014 tri hub?
