replacing head gasket on apex rtx
cam007
I replaced my head gasket on my apex and after I adjusted my timing. I tried to start it. My warning light is flashing and the number 11 & 22 is also flashing on the screen. My apex seems to be turning over fine but I'm not getting any spark. I checked all the wires and made sure that everthing was plugged in. Not sure what the problem might be. Does anyone know what might be wrong.
cam
Code 11 is the Cylinder Identification Sensor. It will stop the sled from starting. I would double check the connection again.
Code 22 is the Intake temperature sensor, your sled should still be able to start though.
