Replacing MTX sliders
froines
Missoula, Montana
Are there any helpful links showing how to replace sliders? Any ideas on where and what to buy would be appreciated. Thanks.
Buy some Hiperfax if you are tired of the stockers wearing out. They are more expensive, but last a long time.
Loosen the track and remove the screw at the front of the skid, spray a bunch of WD40 up and down the rails, then use a hammer and punch/screwdriver to tap the old hyfax back through a track window. Raise the rear of the sled up in the air - start it up and put it into reverse and the hyfax will peel right out as the track spins backwards.
If your sled does not have reverse - you can build a slide hammer with some all thread and an old set of vise grips.
We use a little dish soap on the new ones to get them to slide on better.
