Jona$
Master
- Sep 27, 2010
- Northern
- Sweden
- Tapex/sks 800 -16
Noticed that the Tapex got hardstarted, it sure is 100% a leak of a injector and my money is on the shitty black injectors from mcx.
My question is repair or replace, and if so with what.
Also any improvments some one know to the bov, different spring or replacing the bov?
mbarryracing
- Aug 31, 2007
- Springville NY
- 2006 Yamaha Attak Turbo
2015 SR Viper RTX-DX
1996 Vmax 600XT
We were wondering wat you had determined to be the issue that was causing you hard starting, if it was a flooding issue or not. You should update a post on your Hardstarted Tapex thread about what you found.
All I can recommend is that you replace the leaky injector with any same flow rated injector so i matches the MCX programming.
TT
Get Bosch injectors from MCX and reflash your fuel box at MCX. They have a fuelmap for brown Bosch injectors to the 290 hp kit ;-)
BADSLED
- May 13, 2004
- Syracuse, NY
- 2025 Sidewinder XTX LE EPS
2012 Nytro MC Xpress 270
TT said:Get Bosch injectors from MCX and reflash your fuel box at MCX. They have a fuelmap for brown Bosch injectors to the 290 hp kit ;-)
So, the Bosch injectors are available through MCX still for replacement?
TT
Yes!
Jona$
Master
- Sep 27, 2010
- Northern
- Sweden
- Tapex/sks 800 -16
Old as hell, but it was the EFI gen 3 that the bar sensor got messed up that was the problem.
This year it seem to be the black injectors.
Have a thread about it.
Why the f is my mcx popping
