TheFarm845
- Jan 19, 2022
- Minnesota
- 2022 Sidewinder LTX LE
Ordered a muffler for my sled, It only has 14 miles on it. I'm wondering if the factory exhaust gasket going from the turbo to the muffler is a "crushable" style or can it be reused being so new? Just curious to whether I should order a new one or not.
Big_Phil
- Feb 5, 2014
- Wasaga Beach, Ontario
- Sidewinder RTX LE
Good to reuse
Turboflash
- Mar 18, 2019
- Southern MN
Factory spec is 9 ft.lbs in criss-cross pattern, then 18 ft. lbs final in same criss-cross pattern.
Turboflash
- Mar 18, 2019
- Southern MN
From most of the sleds that have come through my shop, MOST sleds they are way over-torqued!
Big_Phil
- Feb 5, 2014
- Sidewinder RTX LE
I don’t know if it’s the material of the bolts or what, but these exhaust bolts tighten differently than a regular bolt. I do them with my impact and when they are tight they just stop. A normal bolt will keep tightening slowly till the head snaps off if you hold it. Never had an issue removing and installing many times.From most of the sleds that have come through my shop, MOST sleds they are way over-torqued!
NYTurbo
- Sep 26, 2017
- Ottawa
- Sidewinder
Concern yourself with a good high temp anti seize on threads more than torque values on those bolts.
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
Bingo.. And then the guy posts why his bolt broke off taking bolts out.. I literally just snug mine with anti seizeFrom most of the sleds that have come through my shop, MOST sleds they are way over-torqued!
Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
Just don’t over torque them and yes, use some Nickel anti seize.
I find that even if I do both, they come out hard again next time unless I use a bit of heat on those bolts!
Probably has something to do with hot and cold, expansion and shrinking!
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
X2...must do thisbit of heat on those bolts!
stgdz
- Mar 27, 2021
- Buffalo MN
Seen sparks fly off the bolts the first time in un torqued them.
Hammer70
GRIPNRIP
- Sep 6, 2015
- Niagara, Ontario.
Sparks fly you using air or electric tools on them ?
NYTurbo
- Sep 26, 2017
- Ottawa
- Sidewinder
Helps to run sled to get turbo hot then remove bolts if your having an issue
stgdz
- Mar 27, 2021
- Buffalo MN
From the manifold bolts. Those suckers were tight!Sparks fly you using air or electric tools on them ?
Fleecer
- Jun 13, 2014
- 2019 SRX
I've re-used it a dozen times without issue.Ordered a muffler for my sled, It only has 14 miles on it. I'm wondering if the factory exhaust gasket going from the turbo to the muffler is a "crushable" style or can it be reused being so new? Just curious to whether I should order a new one or not.
DooZ
- Feb 26, 2007
- Minocqua, WI
- ZR9000RR
Doo 1200
I've found chasing the threads, cleaning them has worked well prior to reinstall as well. I haven't had any problems yet torquing to 10ish ft lbs w/nickel antisieze getting the bolts out multiple times. Always have reused the stock gasket.
- 8K
